08' xl1200c 19" wheel & tire
I need a new front tire anyways and I think I prefer a 19" wheel. I can get a used 2014 883 iron 19" 13 spoke wheel P/N 47875-09A on Ebay that I like and think is compatible. Harley has 19" wheels they list for my bike, but not tires?
1. Is that wheel compatible 47875-09A?
2. Can I use the Dunlop 401F 100/90H-19 tire?
3. Or do I have to use the 401F 90/90-19?
HD does not make figuring this all out easy that's for sure!
I would appreciate any input or recommendations.
2 - Yes - but the 401 is a mediocre tire in my book. I like Metzeler 880/888 tires better.
3 - No
I swapped the 21" front wheel for a 19" on the bike in the sig pic.
Much better handling and better tire mileage with the 19.
I have been fretting trying to figure this all out with the 3/4" axle, 1" axle and 25 mm axle. It is much more economical to go with a used wheel, but they are mostly on Ebay and I don't want to buy the wrong wheel and be stuck with it. Now, I will feel more confident about what I'm talking about when I approach a cycle shop about doing the work.
So, if I get a wheel 2000-2007, do I just have to get the installation kit and that will accommodate for the different bearings or installation kit and have bearings changed? That will open up other options for me then.
Also, it's kinda weird, there is no visible damage to the 21" original OEM Lace-spoked wheel, but it definitely doesn't roll straight? Who knows? I knew when I bought it that I wanted to switch the wheel out anyways.
One question - is the 2008 XL1200C a narrow-glide or mid-glide...my 2011 XL1200L is a narrow-glide?
Welcome to the forum.
When you get a Front Wheel 25mm bearing installation kit, it will come with the Shim/spacer that will allow you to use the earlier wheels on 08-later bikes
My recommendation would be to buy the Shim/spacer only, re-use your existing center spacer sleeve (or buy another), and get better quality bearings.
if you need any part#s, LMK
Don't need any special spacers for his application
