Engine Miss
Old Sep 10, 2016 | 03:30 PM
Deadey34's Avatar
Deadey34
3rd Gear
Default Engine Miss
I have a 06 883 with a off idle miss. It happens when you just start to accelerate. It will open up and run fine. It misses only when you crack the throttle open. Thought it was the he accelerator pump , but, it was fine. I have cleaned the carb, checked for loose/croded wires and a under voltage at the battery while running. Also checked for a vacuum leak. An help would be welcome.
Old Sep 11, 2016 | 12:32 PM
John Harper's Avatar
John Harper
I'd replace the accelerator pump diaphragm if it's from 2006. Then set your idle mixture when engine fully warm.
I just replaced my original pump diaphragm on my 1991(!), it was all stretched out. What a difference the new one makes, no coughs or hesitation.
John
Old Sep 13, 2016 | 10:45 PM
Deadey34's Avatar
Deadey34
3rd Gear
Default Got it fixed
The carb was to lean. Runs like it should. No studder at all. Thanks for the help.
SoALposer
Carburetor Related
Jan 11, 2021 06:18 AM
ezmo
Shovelhead
Aug 23, 2013 02:44 AM
fiveola
Shovelhead
17
Dec 6, 2012 07:49 AM
pleasants9
Jan 31, 2011 10:16 AM
sportster_fiend
Jun 25, 2008 10:10 PM
