I'm replacing the stock springs on my 08 Sportster, my question for anyone that has done this is, did you cut the PVC spacer or use the ootb length? With the thicker spring and tighter wind I don't want to compress it too much, but I don't want to cut the spacer and drop the height and screw up the preload.
Thanks
i did not cut mine. it's a preference thing, per the instructions. i have serious stoppers up front, so i want little to no dive.
Thanks
You can try it without cutting first and then see how you like it.
You could also use a piece of like diameter PVC pipe from a home supply store, cut a couple pieces to the desired length and try that without altering your the Progressive spacer.
Mine called for a 3 inch spacer. I cut new ones to 3 and 1/8. 3 inch gave me a little too much sag. 1/8 longer was a bout right. You need to measure sag. Measure it with the bike weight and with you on the bike. That's the only to get it right.
Good suggestion, but use a proper pipe cutter, to keep the ends square. Don't rely on a hacksaw! Of course if you have a lathe, that would be perfect. The whole purpose of using spacers is to adjust sag with you sitting on your bike, to approx 1/3rd of total fork travel. That will give you an optimum ride, within the limitations of our forks.
I usually cut PVC with my table saw or power miter saw both with carbide teeth blades. Makes a very clean and true cut. A bit of dust though. . .
Thanks, I cut the spacers to 3 3/8, took it for a ride on some choppy roads and it felt great. The only problem is now I realize how much better the front suspension is over the rear. . I rolled over small stuff with out even noticing, the big hits were noticeably softer. I even ran a little to low for third gear and the it was much smoother.
I used a pipe cutter to make sure that I had an even cut all the way around.
Thanks for the help.
A couple of us have installed 12" 412-4068C or B rear shocks with good results. Plenty of travel, smoother ride, and no bottoming. The 4068 12" has a HD spring even though it is listed as "Standard" in Progressives product guide. It is one step up from the other "Standard" grade 412 shocks.
Progressive changes the "spring rate" for their 12.5" and longer vs. 12.0" and shorter rear shocks.
The 12.5" or longer shocks provide a noticeably better ride than that with the <=12" shocks.
