getting less vibration can it be done
Old May 6, 2017 | 12:13 PM
  #81
Søren Rix Petersen's Avatar
Søren Rix Petersen
well after the new wires and coil relocate the vibration is now down at least on the first ride he he
plus my new cheap grips helps alittle to
regards
Sören
Attached Thumbnails getting less vibration can it be done-dsc_0313.jpg   getting less vibration can it be done-dsc_0303.jpg   getting less vibration can it be done-dsc_0305.jpg   getting less vibration can it be done-dsc_0307.jpg
Old May 7, 2017 | 05:14 PM
  #82
hscic's Avatar
hscic
regards
Sören
Thanks for sharing....are you saying your spark plug wires were bad which caused the vibration? I have stock wires so if it helps, I will try it.
Old May 8, 2017 | 11:05 AM
  #83
Søren Rix Petersen
yes only did one short ride but it was alot less and getting lesser as it got hotter.
i could feel it when i toke the wire off the rear and again putting the new ones on, way better fit.
regards
Sören
Old May 8, 2017 | 11:26 AM
  #84
multihdrdr's Avatar
multihdrdr
For getting the last bit of vibration out...
Did you get your wheels re-balanced after ADDING those Heavy SKULL Valve Stem Caps?
Old May 8, 2017 | 01:03 PM
  #85
Søren Rix Petersen
since i don´t like adding blink no, but when i get the rear rim extend to 4,5-5 ill get new tires and get them re-balanced.
i was only trying to giv info on what worked for me
regards
Sören
dazhansen
Mar 31, 2015 08:07 AM
missedem
Jun 15, 2014 07:13 PM
2011FXDC
Mar 15, 2012 11:08 PM
topgun1056
Jan 24, 2012 09:30 PM
JBA111
Dec 24, 2006 03:28 AM
