Gears
Old May 6, 2017 | 01:34 PM
Mojo7's Avatar
Mojo7
Default Gears
Does anyone know how you check the gear oil on your bike. Looked through the manual but got utterly confused. I thought I read it should be changed every 10 grand but not 100% sure.
Old May 6, 2017 | 01:40 PM
JustDave13's Avatar
JustDave13
Check or change? FWIW I change mine every 15k and it still comes out clean. The next time out I'll change it at 20
Old May 6, 2017 | 01:51 PM
sawka's Avatar
sawka
Check I've never heard of being done. It won't use gear oil unless you have a leak. The interval is every 10k. Actually not bad at all to do. I just do motor oil every 5 then motor oil and primary every 10. They also say adjust clutch every 5 but it's never been odd so after a while I only adjust the clutch every 10k.
Edit: the only check you're going to be doing in there is on your chain. Even the clutch you don't check, you just zero it out and set it. As far as fluid to add just sear h the forum. Please don't reignite the great oil debate of 2015. Many lives were lost.
Old May 6, 2017 | 01:56 PM
JustDave13's Avatar
JustDave13
That's how I do it on my bike. Oil and filter every 5 and primary every 10. IIRC on Sportsters the trans and primary share the same oil so I would do that every 10.
Old May 6, 2017 | 08:47 PM
Mojo7's Avatar
Mojo7
Thanks guys. I'm just wondering how you know you have it full enough when you change it. Not even real sure where or how you fill it. I'm a total greeny learning as I go.
Old May 7, 2017 | 01:05 AM
Iarecobra's Avatar
Iarecobra
If you have reason to believe its low then drain and refill. Cheap insurance.
The drain plug is on the bottom, don't loosen the primary chain adjustment nut. The drain plug is next to it.
Replace the O-ring. They are reusable but again, cheap insurance
On the left side (if your sitting on it) there is a small round or oval cover with 2 star bolts. That's the primary chain inspection cover. Stick a funnel in there and pour in exactly 1qt of your preferred primary fluid.
Replace the inspection cover and you're done. Sit back and enjoy a cold one.
Old May 7, 2017 | 09:04 AM
Kenny94945's Avatar
Kenny94945
To check...
Level the bike.
Remove the derby cover.
Look for oil level to be at the base of the clutch basket teeth.
Manual has a diagram of the oil level to teeth.
For "insurance" buy a replacement derby o-ring...$2.50
Yet going this far into checking, might as well replace.
Not sure if the oil would leak into another chamber inside the engine.
Outside leaking would be obvious.
Good luck.
Old May 8, 2017 | 01:59 PM
grbrown's Avatar
grbrown
Talking
What manual are you referring to? The factory service manual has a section dedicated to changing trans oil, plus a maintenance schedule. Doesn't take that long to read it from cover to cover, so you know where everything is......
DanMan1
Shovelhead
Dec 26, 2013 10:58 PM
81TourKing00
Sep 13, 2013 08:07 AM
masterblaster
Jun 27, 2012 12:00 PM
Big_Al47
Feb 3, 2011 03:58 AM
lecomte38
Oil Archive (no new posts)
Mar 31, 2008 03:44 PM
