BIG PROBLEM, NEED HELP!
Old May 31, 2007 | 04:57 PM
ronn39's Avatar
ronn39
Default RE: BIG PROBLEM, NEED HELP!
55-65 foot pounds. I believe the factory originals where supplied with a pre-included loctite, and if you're not using OEM bolts, you want to be sure to use loctite on them (I use blue, red is forever stuff). Sounds like those three bolts were severely over-tightened to the point that they were weakened, but not to the point that they broke under the heavy wrench -- eventually breaking under use. That locking stuff HD uses is tough stuff and I've sometimes wondered if I wasn't going to bust a bolt trying to unloosen them.
PS: The factory says don't reuse those bolts, so if your already replacing three, you might as well replace the other two as well.
Down2Ride
Aug 11, 2021 01:16 PM
Rsbenden
EVO
Jul 23, 2019 05:26 PM
Dalisword
Oct 3, 2012 01:47 PM
nickel dime
May 26, 2012 03:33 PM
un3asyrider
Oct 13, 2009 03:41 PM
