"Stuck" Directional Switch
Old Mar 4, 2017 | 06:37 AM
Thumper26's Avatar
Thumper26
Default "Stuck" Directional Switch
The right side directional button on my 2005 1200 Roadster is "stuck". It moves slightly when pressed but will not activate the signal. I am wondering if the return spring on the switch got jammed. Anyone else ever run across this issue with their directional switch?
Old Mar 4, 2017 | 07:02 AM
Iceman24's Avatar
Iceman24
Have to ask...did it just start sticking for no reason, or any bar/grip/switch work on the Right that might've caused the problem?
Old Mar 4, 2017 | 07:35 AM
cvaria's Avatar
cvaria
take it apart and see what's up. way easier that it sounds. the little spring or nibs may have failed or gone missing. does require much time.
Old Mar 5, 2017 | 07:03 AM
Thumper26's Avatar
Thumper26
An excellent question. I had an Indy rebuild my front brake master cylinder and the directional switch stopped working about 2 weeks later. My reaction was that he had caused something to go awry, but why would it take 2 weeks to materialize as a problem? Regardless, I have the switch problem and must delve into it, but with the temp at 13*, it will have to wait a bit. I was just hoping someone else had run across this problem and could provide some insight to its resolution.
Old Mar 5, 2017 | 07:19 AM
tmac00333's Avatar
tmac00333
I had the same problem on the other side. WD-40 solved it.
Petiej
Electrical/Lighting/Alarm
Aug 21, 2019 06:12 AM
Thumper26
Sep 13, 2016 08:42 AM
traveler
Oct 8, 2011 08:15 PM
FATBOB.
Mar 6, 2010 09:17 PM
28gauge
Feb 18, 2009 03:04 PM
