Switch problem
Old Mar 4, 2010 | 08:31 PM
FATBOB.'s Avatar
FATBOB.
Default Switch problem
has anyone had problem with thier front brake swith????
i put silcone and it work great for 2 or 3 day and than
i gets stuck again....need help please.. how hard is it to
take it apart and clean this thing...2008 fatbob..
thanks for your time..
Old Mar 4, 2010 | 09:30 PM
drfalken's Avatar
drfalken
You sure its not just backing up in the hand control. There is a little shim in between the back of the switch and the inner wall of the switch housing. Mine didn't have enough tension in it. The switch would walk its way toward the grip and the brake light would be stuck on all the time. I solved it by cutting a shim out of the little plastic packaging that Craftsman sockets are attached to. I stuffed inbetween the inner wall of the switch housing and the back side of the switch and all is well since (over a year ago)
Old Mar 5, 2010 | 09:43 AM
ryderbiker's Avatar
ryderbiker
Good advice on the shim. I spent 2 hours last night trying to chase down electrical demons on my bike and it ended up being the front brake switch. I pushed it forward in the housing but I'm going to do the shim thing to make sure that thing doesn't back out again.
Old Mar 5, 2010 | 10:15 AM
mikel61101's Avatar
mikel61101
pictures please...
Old Mar 5, 2010 | 10:24 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Check out this post by mud from this thread Brake switch ...:
Originally Posted by mud
did you drop and lose the little wedge (spring clip)??
The piece I speak of is #6 below.
May or may not be your problem.
Old Mar 5, 2010 | 06:13 PM
drfalken's Avatar
drfalken
That part doesn't have enough tension. Mine was in there but it was almost fully compressed. Made my own little wedge, solid plastic part from a craftsman socket package. Cut it to size with wire cutters.
Old Mar 5, 2010 | 08:44 PM
ryderbiker's Avatar
ryderbiker
Yeah mine doesn't have one of those.
Old Mar 6, 2010 | 09:17 PM
FATBOB.'s Avatar
FATBOB.
Thanks alot for your help guys...i will try that for sure....
i did read mud post and it did help also..thank again.
Thumper26
Sep 13, 2016 08:42 AM
sknyfats
Sep 12, 2015 11:54 AM
TheBanditColorado
EVO
22
Oct 2, 2013 03:17 PM
ssmith579
Oct 21, 2011 11:14 AM
hbski
Dec 13, 2006 08:21 PM
