my front o2 sensor went out and I went to buy a new one online at JP cycles and once I got it, the plug was different and now I'm wondering why. It also was an 18mm plug which was weird but my pipes have an 18mm bung so it was okay. The part that had me not able to replace it was that it was a 2 pin connector and mine was a 4. Anyone's input on this would be appreciated. I called them to inform them that it was wrong on the website that it fit my bike and they said that there's no where where it shows I should have a 4 pin plug. In the end I'm just going to return it and go to the stealership and order one. I was just lazy and didn't want to drive there but now I might as well have since I spent the same amount of money. It's a 2015 sportster 48. Anyone else can contest that it is indeed a 4 pin connector for the o2 sensor?
that is very important info. In my case, it states 5 years or 18,000 miles and I have 24k, and it says without alterations, and changing exhaust systems is alteration
