Idle High and then low and high then low.
Old Aug 26, 2017 | 04:03 AM
Dale265's Avatar
Dale265
Stage I
Default Idle High and then low and high then low.
I have a 2007 Heritage and at times, my idle races for a few seconds then drops back to normal..then races again, then drop back to normal...What could be the problem here?
Old Aug 26, 2017 | 09:39 AM
bad tappets's Avatar
bad tappets
First problem is you posted in the Sportster section, should be in the Softail forum.
Problem with your bike is probably the idle air control (IAC). The IAC is small thing inside the top of the intake manifold just behind the air cleaner. It probably needs cleaning.
Remove the air cleaner, and use some "mass air flow sensor" cleaner. Spray cleaner on the IAC while turning ignition switch on and off. Cycling the ignition on and off will activate/deactivate the IAC, you will see it move.
Old Aug 26, 2017 | 09:46 AM
John Harper's Avatar
John Harper
I agree, IAC most likely culprit.
John
Old Aug 26, 2017 | 09:58 AM
Iron lHorse's Avatar
Iron lHorse
It could be a hole in your fuel line inside your gas tank . Does your gas tank sound like a hiss for more then 3 or 4 seconds when you turn the ignition switch to ON . You can also look inside the tank when the gas is very low for this problem. There should be NO gas sparying anywhere inside the tank .
macnab_sf
Jun 16, 2020 04:23 PM
cpl_dvldog
Oct 5, 2017 05:32 PM
Hoginedgewood
15
Jul 26, 2017 09:47 PM
Billy W
Apr 3, 2017 10:49 PM
FXD_noob
Nov 18, 2015 10:07 AM
