Seventy two wobble???
Old Oct 6, 2017 | 03:28 AM
sorensentyler's Avatar
sorensentyler
Low tire pressure, cupping on the tire, dry tires (check date codes they made be old harley recommends replacing at 5 yrs old)
Check the steering head. A fall away adjustment may need to be performed.
Old Oct 6, 2017 | 08:44 AM
FMB42's Avatar
FMB42
Low tire pressure, cupping on the tire, dry tires (check date codes they made be old harley recommends replacing at 5 yrs old) Check the steering head. A fall away adjustment may need to be performed.
This very important advice should be a Sticky.
Old Oct 6, 2017 | 10:10 AM
Jackpoticorn's Avatar
Jackpoticorn
Hey guys, thanks for all this. I think it's probably a combination of factors, but first and foremost, his wheels were 5lbs light in the front and 10lbs light in the rear! Hopefully this fixes the issue but I'm also going to have him get his spokes checked
Old Oct 6, 2017 | 02:14 PM
FMB42's Avatar
FMB42
Also make sure that the tire beads are fully seated.
Old Oct 10, 2017 | 10:47 AM
hmnavy72's Avatar
hmnavy72
I run 40psi front and rear, when two up or have cargo ill run about 42-44 in the rear.
on the factory spec Harley tires.
Old Oct 12, 2017 | 03:29 PM
KANSASCITYTECH's Avatar
KANSASCITYTECH
Stage III
My friend and both have 72s, and we have both experienced that wobble. He and I both agreed it went away after spending a good deal of seat time on the bike. I thinks its a stack up of the thin front tire, mini apes, and laced wheels. I ride very loose (i.e. soft touch on the bars) and I've not had any problems for 3000+ miles.
But get every thing checked anyways, can never be too careful.
Old Oct 12, 2017 | 09:18 PM
hmnavy72's Avatar
hmnavy72
Hit the big 20k miles today, been across the country on mine, no wobble what's so ever.
you should check everything on yours, from tires, to their psi, to spokes, to the triple three, rear wheel alightment. Maybe even the balance on the wheels.
Eldon Laue
2014-2024 Touring Models
Sep 5, 2015 12:23 PM
kingnothing71us
Jul 26, 2015 05:51 AM
les63
Apr 23, 2008 03:54 PM
jonah
Jan 23, 2008 03:24 PM
joe v
Jul 30, 2006 02:24 PM
