rev limiter or something else?
Old Nov 15, 2017 | 06:04 PM
patato-patato's Avatar
patato-patato
Default rev limiter or something else?
hi all......just trying to get a feeling for what a rev limiter should feel and sound like. The reason i ask, is because when i open er up (usually in 2nd gear) it pulls very hard with no hesitation at all until at some point (no tach) , it just falls on it's face like someone turned off the key. Oh, and sometimes it makes a cough or popping sound then takes a couple seconds to recover always having me pull off unto the shoulder. The last time it happened the motor died but restarted ok.
Iv'e seen videos of "rice-burners" that run up on the limiter and they hold the rpm to that level and you just hear a wa-wa-wa-wa- as it maintains that max rpm. Does this seem normal for an 05' 1200 or should it transition into a more suttle, predictable cut out than that?
Old Nov 15, 2017 | 08:05 PM
firehawk6's Avatar
firehawk6
From my limited experience, it will feel/sound like you hit the kill switch. I don't know how Harley does it but, either the fuel is cut off, or the ignition is.
I've only bumped into the rev limiter twice, and it feels like the bike was shut off until the revs fall below what the limiter is set at. Mine has never made any abnormal sound when I hit it, it just 'dies'.
Old Nov 15, 2017 | 09:41 PM
Dsrieth's Avatar
Dsrieth
Sounds more like a carb problem to me. Rev limiter is in place to keep the engine from gettin turn to fast. It basically feels like u let off the throttle when u hit it, or suddenly abbot the brakes.. The bike just falls on its face and quits accelerating.
Old Nov 15, 2017 | 10:02 PM
Bowhunter8607's Avatar
Bowhunter8607
It feels like the fuel is cut off intermittently really fast and the rpms will bounce around, sounding like the bike is sputtering as you described and like this...
And this at about 14 seconds into the video...
It should not cause your engine to die though. Sounds like you may have other issues. Mine kicks in at 6300 rpm and sounds exactly like the bikes in the videos. Bike just stops pulling.
Old Nov 16, 2017 | 06:14 AM
FMB42's Avatar
FMB42
Unless I'm mistaken, you machine has a factory rev-limiter that's set to 5400rpm. However, this limiter should not 'kill' your engine outright (as other forum members mention). Sounds like you have a fuel and/or ignition problem (again, as previously mentioned). Checking the plugs and fuel filter and fuel lines would be a good place to start. Also make sure you're running fresh fuel that isn't contaminated with water and/or rust/dirt, etc.
Old Nov 16, 2017 | 07:47 AM
apache snow's Avatar
apache snow
I was thinking they are between 6 and 6500. Mine is set at 7400 but I'm not any where close to stock.
Old Nov 16, 2017 | 08:06 AM
firehawk6's Avatar
firehawk6
I think mine kicks in at 6,000 rpm.
Old Nov 16, 2017 | 08:19 AM
cHarley's Avatar
cHarley
The rev limiter should kick in at ~6200 RPM. From the chart below match your gear to the 6200 RPM line and you'll know about what speed the limiter should kick in for that gear.
Old Nov 16, 2017 | 10:58 AM
mrfikser's Avatar
mrfikser
if the bike is dieing it is not normal....the bike shuts off the injectors at a certain RPM (redline) ..once the RPM drops below that set point (by a few hundred RPMS) the injectors turns back on...in the old days (carbs) they would turn off the spark ...does the bike have any codes??
Old Nov 16, 2017 | 01:53 PM
patato-patato
Dont know about codes i've always been afraid to get into that for fear of dropping required settings and so forth.
In 2005 they still had carbs........ and it does feel like the spark cuts out. When that happens it doesn't come back for a couple of seconds. It just seems like such a long time before it recovers (?)
I might be confusing the "cut out" style of limiting rpm's with the "bumping up against the governor" style of limiter, if that makes any sense. It might just be normal and i'm just expecting it to be something more subtle., dun-o
