I have modded almost every part of my bike minus the braking system and it is about time I get around to it. Having a fast bike with low braking power is like having a snooze button on a fire alarm.
Because I swapped wheels, dual disc setup is not an option for me. However, I will be replacing the stock 2 piston caliper with a 4 piston drop in replacement. I am debating on stainless hoses but the stock ones and stock master cylinder should work fine.
I will post back with my results and install when my parts arrive.
Thanks Cvaria! I am likely going with the designer series in pearl black from magnum shielding as far as the lines are concerned. The one piece EZ align is cheaper but I think the two piece is probably better.
As far as pads and rotors, I am gonna wait and see how the stock pads feel on the old rotor. I believe the new caliper comes with new pads on it already so when I wear down the pads I will replace the rotor. I was considering a floating rotor just for the looks as it is not necessary for the type of riding I do.
I am having trouble finding something that fits the rear of my 2011 48. I was hoping to upgrade to stainless steel brake line on the rear. I called magnum and they said they would be willing to look at a picture and see if the engineering team can figure something out.
call them, it may not be easy to find. speigler will just build it for you though. the 2007-2013 rear line is/was kinda funky to add a location for the brake light switch and route from below to above the swingarm.
Hey Cvaria.
Is this the same rear line you posted a picture of above? Your picture looks exactly like what I need but I want it in black. I am having trouble finding a rear line. Stealership can order me one but its only in the bright stainless color as opposed to black.
