Added 4' risers
Old Jan 3, 2018 | 02:07 PM
IronReck's Avatar
IronReck
Default Added 4' risers
I added 4' risers to my 09 sportster as I'm added the controls back on it seems that I don't have anymore slack as I use to. Question is am I supposed to have slack or was it just that I had to much to begin with. And if I need slack what would be the cons on having little to no slack for the brake clutch and throttle cables.
Old Jan 3, 2018 | 03:54 PM
maverick31210's Avatar
maverick31210
You've got less slack now because the cables need to go an extra 4" to reach the new position of the controls.
Little to no slack will cause extra stress on the cables. You should be able to move the bars from lock to lock freely. Mine are the same way...I'm maxed out between risers and bar height to where a half inch more I wouldn't be able to turn from lock to lock.
If it's an issue and you're not clearing or you start to break cables, you need longer cables.
Old Jan 3, 2018 | 07:20 PM
John Harper's Avatar
John Harper
With 4' risers, I hope you aren't planning on ape hangers. You'll have to stand on your seat to steer.
John
Old Jan 3, 2018 | 07:38 PM
misput's Avatar
misput
oops, wrong post
Old Jan 4, 2018 | 12:02 PM
deadrubberboy's Avatar
deadrubberboy
John
Beat me to it. 4 feet of rise sure seems excessive.
Old Jan 5, 2018 | 11:10 AM
IronReck's Avatar
IronReck
but if I am able to turn it shouldn't be a problem
Old Jan 5, 2018 | 11:11 AM
IronReck's Avatar
IronReck
oh **** missed that meant 4" hahaha
Old Jan 5, 2018 | 11:53 AM
maverick31210
You'll probably be alright...I would just check the cables once in a while to make sure nothing's starting to come apart.
Old Jan 5, 2018 | 01:44 PM
arthur6's Avatar
arthur6
You'll have trouble if you don't use longer cables.
I've seen a LOT of crashed bikes because of this.
Old Jan 10, 2018 | 10:38 PM
IronReck's Avatar
IronReck
what length?? And why the crashes bikes?
