Added 4' risers
Old Jan 10, 2018 | 11:15 PM
Russty__'s Avatar
Russty__
this thread made me lol.
Old Jan 11, 2018 | 12:53 PM
maverick31210's Avatar
maverick31210
Originally Posted by IronReck
what length?? And why the crashes bikes?
Whatever length you need to give you enough slack based on where your controls are...it's different for each set up. If you want to go longer, go a few inches longer than what you have now if you don't have enough slack. You can also use string to measure out how much longer you'll need to go if you're planning on going higher.
Crashed bikes because the tight cables will restrict your steering and also because over stressed cables can break.
It's why I asked you earlier if you can turn the bars from lock to lock with your current arrangement.
Old Jan 12, 2018 | 02:38 PM
IronReck's Avatar
IronReck
with the risers and the z bar it's 12" total meaning I should buy a kit for 12"? And yeah when I turn far right the brake line is on the tire.
Old Jan 12, 2018 | 04:56 PM
maverick31210
I would call or message whoever you're buying from and ask what the length of the cables is then measure where you need yours to be and go from there.
Don't assume or you'll get something that is still not long enough or too long which also will not work.
Old Jan 13, 2018 | 10:27 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
We make Handlebar Riser Extensions. The longest we make is 3" because most HD's can go that much higher without needing wire, cable or line extensions.
Going over 3", most will need some extensions.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Jan 21, 2018 | 01:32 PM
wharg's Avatar
wharg
You could try routing the cables outside of the forks, might give you enough slack.
2013 heritage classic
May 6, 2014 06:10 AM
CJinNH
Jul 6, 2011 11:28 PM
pewter sb
Apr 17, 2011 04:14 PM
twisted125
Dec 21, 2009 05:25 PM
capnjim01
Sep 30, 2006 11:29 PM
