brake lights on sporster dont work
Old Jan 26, 2018 | 09:20 PM
hdarmy64's Avatar
hdarmy64
Stage I
Default brake lights on sporster dont work
I have 1995 sportster 883 the brake lights don't work they worked before. I have check front and rear brake switches I even jumped the rear switch and still no brake light it does light up but brake light doesn't work bulb is good
Old Jan 26, 2018 | 11:19 PM
wharg's Avatar
wharg
Might be something else, but I would start with checking the bulb socket for dirt, corrosion, and rust. If it needs replacing, do both sides.
Old Jan 27, 2018 | 05:36 AM
John Ha's Avatar
John Ha
Even before that check the fuse
Old Jan 27, 2018 | 06:26 AM
grbrown's Avatar
grbrown
Wink
A stock '95 Sportster doesn't have fuses, it has contact breakers and each of them tends to cover a lot more than just the brake light, so I think we have to look elsewhere. First thing is the bulb. Even if it 'looks' OK change it - it won't be the first bulb to fail while not appearing to be blown. Then as wharg suggests above check the bulb holder for dirt, corrosion etc. After that it's a case of tracing the wiring, checking for condition and continuity. Many electrical problems like this are actually mechanical, in other words something is stopping the electrickery from getting through to its destination.
Old Jan 27, 2018 | 08:40 PM
14GuineaPig's Avatar
14GuineaPig
I'm looking at the wiring diagram for the 1995 Sportster and it show 4 fuses (ignition, instruments, lights, accessory). Check for power at the tail/brake light socket. With the key on you should have power for the tail light. Then using either the front brake lever or rear brake pedal you should get power for the brake light. If no power for the brake light then check for power at the rear brake light switch. The Orange/White stripe wire should have power to the switch and the Red/Yellow wire should get power when the brake pedal is pressed.
If no power at the rear Brake light switch then check fuse - accessory. The fuse should also power the turn signals.
If you have power out of the Brake light switch on the R/Y wire but not at the brake light socket, then check the wires that run under the rear fender. Sometimes the wheel/tire can chew them up.
Wiring Diagram: https://serviceinfo.harley-davidson....es=0&view=FitH
Page 251 of 332
Old May 2, 2021 | 05:54 PM
Bruce Crowe's Avatar
Bruce Crowe
Stage I
I REALLY like your electrickery as it can be very tricky at times...LOL
Mike62Jazz
Jun 1, 2019 07:15 PM
JEFFREYMJ1*
Electrical/Lighting/Alarm
Sep 8, 2014 10:05 AM
HemiGlide69
Feb 17, 2012 06:38 PM
Calico Jack
Nov 17, 2011 06:29 PM
COFFESLINGER
Aug 31, 2006 09:12 PM
