No 5th gear....need help please!
Ok guys not only am I new to the forums, I am also new to HD. Just bought a 2003 883c anniversary that needed a little work I was told. After replacing clutch cable, new primary shoe due to old one being melted into a ball of plastic.adjusted clutch, cable and reassembled everything. On test drive everything works great, clutch, shifter etc.....EXCEPT 5th gear! At first it was making a grinding noise in 5th gear only but was pulling, after another couple of test runs now 5th gear seems like neutral. Any ideas?
You may have to pull the clutch hub, chain, and front sprocket and inspect the shift drum and linkage before pulling the transmission if necessary. There is a thing called the detent plate which is held by a crappy clip, and the little pins may have come forward or detent plate wobbling. After that, the transmission can be pulled, I believe you don't even have to pull the belt sprocket off the drive shaft on the right side, but I could be wrong. Perhaps a bent shift fork? IDK
You are very lucky with a 2003 for sure. One year later and your entire engine would have to come apart to fix the transmission. You dodged a bullet there as a new Sportster owner. 2003 is a great year, last of the rigid mount engines. Even a blind squirrel finds a nut once in a while.
Worst case scenario, your transmission just pulls out in one unit, easy peasy. Sportsters have strong transmissions so hopefully it's minor.
Good luck and welcome aboard.
John
Your friend may have ridden Big Twins, with separate oil for the transmission. They are nothing like a Sportster engine. Good luck.
John
