Control Cable n00b question....
Old Apr 9, 2018 | 05:13 PM
Aybeesees's Avatar
Aybeesees
Default Control Cable n00b question....
Sorry and thanks in advance...
looking to replace cables, 2000 Xl1200C, I bought a while back. Came with 10 inch apes + stock risers, not my style. Looking to replace control cables. Will a newer year sporty's cables work? I've measured and newer year stock length will work for the new bars I'm running. I've tried looking it up and aren't to clear if that'll be an option. There's plenty of slightly used cables available from riders going + on bars, seems if they will work I could save some $$$......
Old Apr 10, 2018 | 06:34 AM
grbrown's Avatar
grbrown
Wink
A useful source of reference is a parts website, where you can compare part numbers. That won't guarantee an answer, but will help. As an example your clutch cable was introduced in 2000, so I suspect was used for several years after that.
Old Apr 10, 2018 | 01:21 PM
Aybeesees's Avatar
Aybeesees
Great! thanks for the help...
Old Apr 10, 2018 | 03:45 PM
Oddman's Avatar
Oddman
you might try poking around on Magnum cables website. They have some amazing cables and some bike lookup features that might be helpful. https://www.magnumshielding.com/
Old Apr 10, 2018 | 05:39 PM
FreedomRider's Avatar
FreedomRider
Your stock Clutch Cable is #38663-00 ... fits 2000 thru 2003
Stock Throttle Cable is #56400-96 ... fits 1996 thru 2006
Stock Idle Cable is #56401-96 ... fits 1996 thru 2006
Old Apr 10, 2018 | 08:37 PM
Aybeesees's Avatar
Aybeesees
Awesome resource! Thank you!!!
Old Apr 10, 2018 | 08:38 PM
Aybeesees's Avatar
Aybeesees
Whoa thank you! This is perfect, much apriciated.....
Old Apr 11, 2018 | 09:23 AM
craigthecarpenter's Avatar
craigthecarpenter
Cable routing can play a big role as well. Do you have a picture of the bike with the 10" apes installed? Were the cables routed around the fork tube and then back toward the primary and carb? A picture is worth a thousand words.
That year of bike with a CV carb should have Throttle/Idle cables with 5 1/8" +or- of travel and a Clutch cable with 2 13/16" +or- travel.
Craig
Old Apr 16, 2018 | 11:35 AM
Aybeesees's Avatar
Aybeesees
Craig
Sorry for the late late response, yes looks like routed through the fork tubes and back....
Old Apr 16, 2018 | 11:38 AM
Aybeesees's Avatar
Aybeesees
