Handlebar fitment
Old May 7, 2018 | 06:45 AM
SportyChase's Avatar
SportyChase
6th Gear
Default Handlebar fitment
I have been wanting to change my handlebars to the Biltwell Keystones. I believe it is there 6 in model, does anyone know if I’ll have to buy longer brake lines? Just wondering so I can order both at once if necessary.
Old May 7, 2018 | 08:19 AM
Phil13's Avatar
Phil13
Possibly not. I fitted Biltwell Zed bars to my 2017 48. They are 4" rise and while everything else was good, the front brake line was at it's limit when I fitted the reservoir to the bars. I have about 3/4" deflection on the line at full left lock, bit tighter than I'd like, but acceptable.
Old May 7, 2018 | 03:18 PM
grbrown's Avatar
grbrown
This is a common question, however there are so many different bar shapes it is unwise to give a clear yes/no answer! Far better to buy and fit your new bars, then see what else you need to do or buy. Even someone else with the same bars may set them in a different riding position, affecting cable/wiring lengths. If you want a good looking job take your time!
Old May 7, 2018 | 03:59 PM
Dheez's Avatar
Dheez
I installed those same bars on my 2015 Iron, I didn't need to replace any wires. When I went to 12" bars I had to replace brake/clutch wires.
MikeRC
May 25, 2018 06:54 AM
thebarzeen
Jun 27, 2012 08:23 PM
CJP2876
Jun 7, 2012 07:43 AM
ROB9550
Apr 28, 2010 08:03 PM
CWebb3
Nov 4, 2006 10:02 PM
