Handlebar Question
Old Nov 2, 2006 | 07:52 PM
CWebb3's Avatar
CWebb3
Default Handlebar Question
I have an '05 XL883 Standard and I find that being a short person, I need bars that are 1 1/2" - 2" closer to me than the stock ones. Does anyone have any suggestions as to the easiest and cheapest way to accomplish this? I'm hoping to avoid lengthening wires and such. Thanks.
Old Nov 2, 2006 | 08:03 PM
DieHard's Avatar
DieHard
Default RE: Handlebar Question
my 06 883L bars are great i like them alot. not sure if there like yours but look into them.
Old Nov 2, 2006 | 08:26 PM
1garyh's Avatar
1garyh
I put a set of reach bars on my wifes sporty, but had to change clutch cable, throttle cables, and front brake line. But they sure do the job of getting the controls closer!
Old Nov 3, 2006 | 07:41 AM
bamclean's Avatar
bamclean
Any change you make will require a new brake line and probably lengthening the wires a couple of inches. You can find a good selection of pullback drag bars on ebay which is what I would recommend if you're going to go to the trouble of changing them.
[IMG]local://upfiles/20214/85D19C9661024AC0BF4D266B90A22B89.jpg[/IMG]
Old Nov 3, 2006 | 10:35 AM
JohnK/Pa's Avatar
JohnK/Pa
It depends on the bars you have now, but maybe you could add some short pullback risers to get what your looknig for without changing too much. Just a thought.
Old Nov 3, 2006 | 03:37 PM
GLewis's Avatar
GLewis
I put a set of pull back risers on my 05 xl883 this past week end. I did not have to change any cables or lenghten any wires. The risers were 4 inches up and i inch back. I had to move the turn signals to mount on the forks. They hit the tank with the new set up.
GLewis
Old Nov 3, 2006 | 04:35 PM
CWebb3's Avatar
CWebb3
Thank you, that's what I wanted to know. Even 1" back would help. Were there any problems with relocating the turn signals?
Old Nov 4, 2006 | 10:02 PM
GLewis's Avatar
GLewis
No I did not have any problem relocating turn signals. bought a set of fork rings from Phatt performance. You do not even have to cut the wiring. Just take the head light eyebrow lose and the wiring will slip right in behind it. To keep my speedo from being at a funny angle I moved it. I used two 11 mm sockets a s spacers and bolted it to the eyebrow.
Glewis
SportyChase
May 7, 2018 03:59 PM
Cozz
Dec 20, 2015 07:12 AM
DL1986
Jun 19, 2014 09:15 AM
CJP2876
Jun 7, 2012 07:43 AM
bobbyg
Mar 14, 2008 12:53 PM
