Need handlebar help please
Old Jun 22, 2012 | 05:46 PM
thebarzeen's Avatar
thebarzeen
Default Need handlebar help please
Hey guys ( and gals)... I need to replace the bars on my '09 FLHTP.
I am 6'5" and 300#+ ( picture a worlds strongest man competitor) and when I turn to full lock I have to hang my knee off of the bike like a super bike racer so that I don't just hit my knee with the handlebar.
It's really annoying...
So here's the situation I'm in. I need bars that are a good 1.5-2" taller than stock but like most teachers ( I'm a band teacher) I'm barely able to make my payments and mortgage and don't have the $600+ it would take to get all new cables, brake lines, wires, and have the dealer help with the brake ( ABS) plus the few bills for new bars. I CAN afford to spend $200 or so on just a set of new bars.
Has anyone changed over to taller bars without changing anything else? I know you can reroute the clutch cable to gain a few inches, but what about everything else?
Any recommendations on a set of bars that won't require new brake lines etc...?
Supposedly the ergo bars fit the bill, but I'd like to hear from the knowledge base here before jumping in on anything that will eat up my year's worth of toy money...LOL.
Thanks.
Old Jun 22, 2012 | 06:09 PM
KansasKing's Avatar
KansasKing
HD part number 56569-09, notch them for the TBW and a hole at the bottom for the wire to exit. done. check mine and others threads.
Old Jun 22, 2012 | 06:15 PM
mkguitar's Avatar
mkguitar
but first, have you tried shfting the bars up out of the way?
remove the ign switch ( check the youtube how to- do this correctly !)
remove lower dash
loosen to 2 exposed allens on the handlebar clamp
rotate it up
tighten the allens.
put the stuff back on
thanks for teaching kids how to make noise.
Mike
Old Jun 22, 2012 | 06:24 PM
sprintrps's Avatar
sprintrps
56902-08 Heritage Style handlebars are the solution. I am also 6'5" and had the same issue. Bars brought me up and back...problem solved. Bars are only $79.95 and the Dealer charged $126.00 for labor. Total: $ 205.95
Old Jun 22, 2012 | 06:40 PM
TUCCI's Avatar
TUCCI
I don't know my friend, just going by your description you sound massive. I would be looking toward a healthy sized ape hanger in the 14-16" category. Call me crazy but it will pull everything in place for you, but keep reading and come up with your own conclusion but you'll need to go up up up.
Old Jun 22, 2012 | 10:36 PM
thebarzeen's Avatar
thebarzeen
I'm not sure these would work with the EGlide fairing, but please correct me if I'm wrong. Same with the 56569-09's....
I'll play with the bars a bit tomorrow like MKGuitar suggested and see if I can get them up high enough without making a goofy wrist angle, thanks for the suggestion.
And TUCCI, I know that the solution is just to get some apes on there.... but it'll be years before I can put away enough cash to do that properly thanks to bike, car, and student loan payments. I was just hoping to find something that will do for now.
Old Jun 23, 2012 | 01:38 AM
Demolitionman's Avatar
Demolitionman
I only have a little over $200 in my Santee 11" bar install. I bought the bars on here for $100 and the brake line and clutch cable were $119 shipped and i did the install myself.
Old Jun 23, 2012 | 03:19 AM
09FLHT's Avatar
09FLHT
Yaffe sells the classic bagger apes for 100 bucks.
Old Jun 23, 2012 | 06:19 AM
Casper's Avatar
Casper
Khrome Werks + 2 sweepers? Only extra needed is 4 " longer clutch cable...
I bought the KW bars from Powersport junkies for 67.00 shipped...don't remember the cost of clutch cable from HD, but it wasn't much....then do it yourself...should be under 125.00
Old Jun 23, 2012 | 09:56 AM
0ldhippie's Avatar
0ldhippie
I had khromewerks wide sweepers put on my '09 EG. No cable changes. Really like them! Ya could also go with the +2 wide sweepers (or 10-12" apes) and the longer harley clutch cable for under $40 but ya may have to lenthen the throttle wires.
