1986 Sportster lost all power
Old May 11, 2018 | 12:20 PM
cbacon1788's Avatar
cbacon1788
Default 1986 Sportster lost all power
hey guys
while riding my 86 Sportster 883 today suddenly tachometer went hay wire then the bike quit and absolutely no power at all. Bike has a brand new clutch basket, stator, regulator, and battery. I have yet to check the ground wire from the negative terminal on the battery, aside from that any suggestions?
Old May 13, 2018 | 10:06 AM
cbacon1788's Avatar
cbacon1788
Anyone?
Old May 13, 2018 | 10:30 AM
81rat's Avatar
81rat
Not much to go on here bud
BUT --when the elect ign goes bad here's what usually happens
The engine starts great , a little warm up , go for a ride and in about 5 to 10 mi the engine spits , sputters and hard to keep running . Let engine cool down appox 45min and all over again starts , runs good a few min latter and then runs bad
This is 1 of the common things that happens with age on H-D's
ebay --$125
Old May 14, 2018 | 11:53 AM
83XLX's Avatar
83XLX
Sounds electrical, so I'd suspect a loose/shorted wire on one of the components you had replaced, or a loose battery cable. Even though it's new, I'd also check the battery voltage to make sure it's good and maintaining a charge. The electronic ignition won't work correctly with a low battery.
Old May 14, 2018 | 06:09 PM
cbacon1788's Avatar
cbacon1788
Battery is brand new but tested anyways has good voltage 12+..... when I turn the key on I have absolutely no power at all but if I let the bike sit with the key on after 5 minutes or so my lights and everything will come on, but when I hit the start button I can hear the circuit breaker for the lights pop and then everything goes completely dead
Old May 15, 2018 | 02:20 AM
81rat's Avatar
81rat
BAD GROUND -- ad 4ga wires from your bat ground to the engine and also the frame
try a set of jumper cables first
Old May 15, 2018 | 05:54 AM
cbacon1788's Avatar
cbacon1788
Bad ground as in the wire from negative terminal on battery to back of motor? How do you draw this conclusion?
Old May 15, 2018 | 03:25 PM
81rat's Avatar
81rat
DID you try it with jumper cables ????
Or are you going to doubt someone when YOU are the one asking for help
Old May 15, 2018 | 07:52 PM
cbacon1788's Avatar
cbacon1788
easy there cowboy maybe you perceived what I had written wrong, I’m simply trying to understand how you came up with that so I can learn
Old May 15, 2018 | 09:47 PM
normannewguy's Avatar
normannewguy
First, no power to anything? If thats the case I would check ignition switch. It lights up every thing else. It goes bad and bike will shut down. Had it happen to me on 97. Need a voltmeter and wiring diagram of 86, see which wire from batter supplies power , then see if you are getting anything out of the switch.
