Error codes
Old Sep 24, 2018 | 10:10 AM
Mborras1's Avatar
Mborras1
Default Error codes
hello all,
just went out to check the codes on my 13 sportster 1200 custom anniversary edition,because never have done it and wanted to just check.
current set up screaming Eagle A/C PCV with base map running open Lupe o2 and cobra 2-1 rpt full exhaust. No additional engine mods.
I have 2 codes that popped p132 and u1097. looked through the forum and found p132 is an o2 issue and u1097 is speedometer issue. No check engine light and bike seems to running fine. What would be the best course of action? I was thinking reset codes and see if they pop up again and go from there.
here is what i found the codes errors are,
72. P0132 Front Oxygen Sensor High
5. U1097 Loss of Speedometer Serial Data to ECM
thoughts....
Old Sep 24, 2018 | 05:53 PM
mmesa005's Avatar
mmesa005
Contact DynoJet Tech Support and they will walk you through checking to see if the codes are a result of the PCV?
Saintsofmayhemvp
General Topics/Tech Tips
Aug 7, 2019 04:02 AM
sanaga
Aug 7, 2019 04:00 AM
emperor wurm
Oct 21, 2015 01:05 PM
2007z71
Jul 28, 2014 11:01 AM
Chicago Spike
Sep 25, 2007 07:03 PM
