today i install pc V on my 11 flhtk
install succes, unplug the o2 sensor as per the pc V manual.....load a map and the bike ran nice....
after that, i try to run diagnostic mode on the dash
it show P00134, P00154, P00031
134 = front o2 sensor inactive
154 = rear o2 sensor incactive
0031 ??
is it normal ??
manual on PC V said its normal and let it like this....
i want to ask people that has installed pc v on their bike has same error code like mine or not ??
so far no engine light....
Yep, you unplugged the sensors, it is normal, as far as I have read. Now, I have no clue if mine tripped those codes. I installed my PC-V last year, ran like a champ, did not go into diagnostic mode looking for troubles since there was no check engine light.
Get out and ride, stay safe.
hey thanks bro....
mine also no check engine light....
if u can get into the diagnostic mode, let me know what code do u have there....thanks bro..
Installed a PC-V 15-011 on my 2012 103ci SG with about 400 miles on it a couple weeks ago... No mods on the bike, so I'm running the stock set-up map from the PC site 15-011-057. had the bike out a couple times this past week for the first time since install and on occasion, the bike has been idling rough after warm-up. Almost sounds like its running on one cylinder. Roll the throttle and it clears up until I let it idle again. Sometimes it does it, sometimes not.
Turned off thermal management system... Same issue!
I was out riding the other day and upon rolling the throttle after a red light turned green, the engine lost power, I ahead to feather the throttle to keep it alive and get rolling and then it ran fine the rest of the trip...
I checked the diagnostic mode and the following codes displayed:
P-0134 Front 02 Sensor open
P-0154 Rear 02 Sensor open
P-0031 O2 Heater
All of these are normal with the 02 sensors disconnected as per PC-V instructions.
I thought the same but Thermal mgmt was turned off, unless "Parade Mode" you speak of is something else. Also. Don't think I overheated it. It was 45 degrees out and I was only stopped for a minute if that...
Hey guys, I also just did a stage 1 and used the PC V. I got all the same codes and got all of them to clear except the p0031 code. My check engine light is on because of it.....any idea how to clear this?
0031 ??
is it normal ??
please help
thanks
Did you install the optimizers? They should give a steady 5v back to the PCM which fools it into thinking everything is just fine and wil not set codes.
