2002 trap door torque spec
Old Oct 8, 2018 | 10:47 AM
oldsoulmyfriend's Avatar
oldsoulmyfriend
Stage III
Default 2002 trap door torque spec
I just can't find the specs for the trap door on my RK. Last time I looked online I got the wrong spec for my oil pan and snapped a bolt. Any help is awesome thank you
Old Oct 8, 2018 | 11:52 AM
Scuba10jdl's Avatar
Scuba10jdl
Note this is for a big twin, since you said RK. This is the Sportster section. This is from a 2004 model, but it should be the same transmission:
Transmission Side Door
5/16" screws: 13-16 ft*lbs
1/4" screws: 84-108 in*lbs
There is also a torque sequence for these six bolts to prevent distortion.
Old Oct 10, 2018 | 12:31 AM
oldsoulmyfriend
Stage III
Thumbs up
Hey thanks a lot. I did not realize this was a sportster thread but I appreciate your help.
Old Oct 10, 2018 | 07:41 AM
John Harper's Avatar
John Harper
How lame is the FSM Pounds-Feet and Pounds-inch. Yet the measurements are almost the same.
10-18 foot/pounds is 120-212 inch/pounds
84-108 inch/pounds is 7-9 foot/pounds. Ok, I get it you might not want to use a big torque wrench, but this is just past hand tight!!!
Why not just pick one, or the other to list torque values. So lame. No wonder people snap off bolts.
John
Old Oct 10, 2018 | 07:46 AM
Scuba10jdl's Avatar
Scuba10jdl
John
Mostly because of the tools you'll be using. A 3/8" torque wrench typically only does about 20-80 ft*lbs or so. Some may have low values available, but they're super inaccurate. A 1/4" torque wrench is around 50-150 in*lbs, so they list it in that because that's the tool being used.
ubreal
General Topics/Tech Tips
17
Sep 9, 2016 09:28 PM
kyhasumm
Mar 19, 2013 12:26 AM
rkcmike63
Feb 3, 2010 04:37 PM
Adam_T
Sep 24, 2009 08:33 AM
wolfydude
Feb 21, 2009 12:04 AM
