throttle housing clip
Old Oct 12, 2018 | 06:33 PM
riverdawg1's Avatar
riverdawg1
1st Gear
Default throttle housing clip
I have a 97 883 and I installed new throttle cables and housing on right handlebar. While pushing the throttle cable in somthing fell outt of housing. Looks like a small brass v shaped clip. Any idea where it gors?
Old Oct 12, 2018 | 06:58 PM
John Harper's Avatar
John Harper
It might be the little "shoe" that the throttle stop screw (that star wheel thing under the throttle housing) pushes on to provide tension on the throttle barrel. Mine is plastic, but maybe they changed from '91 to '97. IDK, my cables screw into the throttle housing, not push in.
John
Old Oct 12, 2018 | 07:00 PM
Zateeva's Avatar
Zateeva
yep, was thinking the same, i just replaced my cables also..........piece fell out, was the throttle tension screw, u shaped thingy
Old Oct 12, 2018 | 08:52 PM
normannewguy's Avatar
normannewguy
It should go on the throttle tension screw. It keeps the screw from backing out. it's not an expensive part but bad thing is you have to disassemble the right hand control again to get to it.
Old Oct 12, 2018 | 09:18 PM
QC's Avatar
QC
If it is a sharp "V" shaped piece of steel, it goes behind your brake light switch to hold it in place.
Old Oct 13, 2018 | 10:40 PM
riverdawg1's Avatar
riverdawg1
1st Gear
Ended up being the piece that holds brake switch in place. Thanks for the replies
Old Oct 14, 2018 | 03:44 AM
grbrown's Avatar
grbrown
Talking
It's the tiny bits that can be most challenging sometimes - also the most rewarding once found and sorted! Well done for noticing it's escape attempt.
Iarecobra
Jan 2, 2015 08:06 AM
Atlaska
Sep 17, 2014 03:07 PM
STARRY
Jun 1, 2010 08:00 AM
saltlick
Feb 20, 2007 06:35 PM
swomack
Sep 15, 2006 11:51 PM
