Rear blinker loose
Old Jul 2, 2007 | 12:48 PM
possum67's Avatar
possum67
Default Rear blinker loose
...and will not tighten. I noticed a new rattle while riding this weekend and found it to be my rear blinker. Got a wrench to tighten it and it seems the bolt or stud is also turning with the nut?!? tried to pull the reflector from the inside to try to hold the bolt head, but no luck. Anyone got ideas or experienced this? Heard that rattle for 125 miles!!!
Old Jul 3, 2007 | 03:21 PM
bigtop1's Avatar
bigtop1
Default RE: Rear blinker loose
You're in for a big job. Any way that you look at it, you will have to remove the shock cover and hardware to get to the stud. No easy task. This also means the wiring. Keep us posted.
Old Jul 5, 2007 | 10:47 AM
possum67's Avatar
possum67
Thanks Bigtop...I plan on getting to it this tomm nite or this weekend. Will keep updated....
Old Jul 5, 2007 | 02:21 PM
Wolhar's Avatar
Wolhar
Pull the Brake light cover and disconnect the turn signal wiring for the side in question, remove the Strut cover screws/bolts, push wiring towards the hole it passes thru in the fender and remove strut cover and light assembly, you should have enough room now to put some locktite on the screws/bolts and reinstall.
Old Jul 5, 2007 | 06:50 PM
Pioneer's Avatar
Pioneer
I had that happen to me and the Dealer told me that everything had to come off and apart. BULL!!
I popped the lense off and very carefuly pryed the reflector loose with a pocket knife (reflector is mounted in a rubber gasket). You can get it out enough to get a open end wrench in there. Worked for me.
Jimh64
Apr 29, 2019 11:19 PM
dohadex
Mar 26, 2013 07:08 AM
kozy22
Dec 28, 2010 05:09 PM
asparks25
Dec 20, 2010 02:09 PM
Mandog
Aug 3, 2009 12:09 AM
