2009 Sportster 1200 front wheel
Old Dec 23, 2018 | 08:43 AM
Navigator33455's Avatar
Navigator33455
Default 2009 Sportster 1200 front wheel
Hello
I just bought a 2009 HD Sportster 1200 custom. 21" front wheel. Very happy to be riding it. I came from an Indian Scout. The Scout had a shorter, fatter front wheel, 16", 130/90. The tire on the sportster is the original Dunlop (HD branded) MH90-21 (12k miles).
The turning on the Scout was very forgiving, though, almost plodding. The Sporty is very different. Nimble...which I like....but...at first, it almost felt as though the wheel wanted to go over on its own. Not a big deal...but....
I have toyed with the idea of putting a 19" wheel on (100/90?). The front tire would be only 3/4" inch or so less in diameter, but wider. Would this change this steering characteristic to a significant extent?
Alternatively, I would replace the current tire with a Metzeler 888 90/90-21. So, a little bit wider (a tiny bit taller, though). Would that change this characteristic? Would there be a significant different in handling between a 100/90-19 and a 90/90-21?
My first post, so please forgive any ignorance...I have tried to search this, but opinions vary.
Thanks
John
Old Dec 23, 2018 | 10:27 AM
aidoru's Avatar
aidoru
I put a Shinko 777 (Shinko 777 Cruiser Tires, 90/90-21 54H) and handles a lot better than stock.
Old Dec 24, 2018 | 09:05 AM
cacomly's Avatar
cacomly
The Dunlops tend to follow all the cracks, lines, etc that they come across on the road. Simply changing to another brand of tire should solve most of this.
Old Dec 24, 2018 | 09:21 AM
upStomp's Avatar
upStomp
Good to know. I have an '05 and it's my second biggest issue with the bike.
Old Dec 24, 2018 | 09:50 AM
aidoru's Avatar
aidoru
I have a 04 XLC and with the Shinko tires and new suspensions, I feel like I am driving a brand new bike.
While inexpensive Shinkos are very grippy and completely oblivious to road imperfections. I like them a lot.
With good tires, the limiting factor in the bike handling are the suspensions an I became even more painfully aware of how poor my stock set up was. I upgraded the front with to Race Tech springs and gold valve emulators and the back with Bitubo shocks. It is about 1k$ in total but stopped me from buying a new bike...
whylee's Avatar
whylee
I feel the 19" front handles great. I do not like the skinny front tires for the 21". They do tend to catch all the road grooves.
Old Dec 25, 2018 | 06:13 AM
Navigator33455
Thank you everyone, for these great posts. Very helpful information.
The least expensive way to go would be to just put on new rubber. I need to do that anyway. I do not have a lot of confidence in tires that may be 9 years old (12k on the bike, these could be original...I have no way of knowing).
Still interested in knowing if there is a significant difference between a 21" front and a 19". Has anyone ridden both?
Might be a good idea to keep the bike stock, so keep the front wheel. As I wrote, it is really not a problem, I have over 1000 miles on the bike, I ride almost every day. Newly retired, so, more time than money.
Thank you.
John
Old Dec 25, 2018 | 11:45 AM
08xl1200r's Avatar
08xl1200r
Thank you.
John
You can easily tell the tire age as there is a 4 digit code on the sidewall, first two are the week, second two are the year of manufacture. The 2008 Sportster I bought nearly a year ago did have the original tires with a 2007 date code and I replaced them quickly. Swapping to a 19" wheel should be easy if you stick to a 2008+ w/ 25mm bearings. Check out the part differences between a Custom and standard Sportster at http://partsfinder.onlinemicrofiche.....asp?make=hdmc
https://www.tirebuyer.com/education/...-of-your-tires
Old May 13, 2022 | 09:48 AM
fmxdude's Avatar
fmxdude
6th Gear
bump for any info on which setup you went with? im trying to figure out a smaller wider options for my 1200xlc i really want the 48/nightster front wheel but not sure if it will work with stock forks, thank you
alienbogey
Wheels/Tires
Sep 18, 2018 09:30 AM
XX25
Jan 6, 2015 02:44 PM
trat73
Jul 22, 2013 12:02 PM
Bryan53
14
Apr 4, 2009 05:14 PM
thomasf59
Aug 17, 2008 06:55 PM
