python slipon bracket/mounts for sportster
Old Feb 3, 2019 | 04:10 PM
firefighterhoke's Avatar
firefighterhoke
Default python slipon bracket/mounts for sportster
I have a 05 883 that’s came with a set of python slant but slipons but they didn’t come with mounts/bracket that is required to mount the, to my bike looking to see if anyone has this mount they can take measurements and pics of for me I have contacted the company multiple times but no response. Thanks in advance
Old Feb 11, 2019 | 10:57 PM
Johhny51273's Avatar
Johhny51273
Have you verified that the slip ones that you have will fit the bike you have? The Python slip ons I put on have the mounting brackets built onto the slip on.
Attached Thumbnails python slipon bracket/mounts for sportster-photo840.jpg   python slipon bracket/mounts for sportster-photo693.jpg
Old Feb 12, 2019 | 12:25 AM
firefighterhoke
Mine look identical to those and says in the listing on their website comes with a bracket as the original factory slipons have different bolt pattern then the Pythons which have a closer bolt pattern which I need schematics of the bracket that adapts the two
Old Feb 12, 2019 | 09:11 AM
Artax's Avatar
Artax
I have the python 3 slash cut on my 2010 and have a separate bracket. I don't have any good images of the brackets, but I may be able to get some tonight if I think about it. The ones in the image above look to be larger OD than mine and look to have a down slash. mine have the slash cut angled outboard and have python 3 engraved not just python and the engraving is a bit further foward.
Old Feb 12, 2019 | 06:22 PM
Artax's Avatar
Artax
Here are a few pics of the brackets on mine. Look to be about a 45deg bend. Lower leg is about 1” from edge to bend and the muffler leg is about 1.5”-1.75” from bend to edge. Hard to measure on bike. Plate just long enough to mount to stock mount and muffler bracket. Leg for muffler bracket looks centered and front and rear bracket look the same. Hope this helps.
firefighterhoke
Exhaust System Topics
Feb 3, 2019 04:04 PM
firefighterhoke
Oct 20, 2018 06:08 PM
mikeo33y
Jul 23, 2016 09:59 PM
Sand Man
Nov 29, 2015 02:17 PM
harleyheaven
Feb 29, 2012 10:38 AM
