Brake line question
Old Jul 8, 2007 | 08:15 PM
Redsman777's Avatar
Redsman777
Default Brake line question
I just noticed today that my brake line connections into the lever at the handle wiggle when I touch them. Is this normal or have they possibly come loose and should they be tight? Front one has quite abit of movement.I am not leaking any fluid and I still have good brake response. Thanks.
Old Jul 8, 2007 | 08:19 PM
DaveJ's Avatar
DaveJ
Default RE: Brake line question
The brake line connection should be tight, no wiggling. But it doesn't go to the lever, it goes to the master cylinder. Are you possibly referring to the clutch cable? That can wiggle a little.
[align=left] [/align]
Old Jul 8, 2007 | 08:23 PM
Redsman777's Avatar
Redsman777
No, its the brake lines, I just mis-spoke. Yeah, I don't remember doing anything that could have jerked them or anything. Thats why I was wondering. I guess I'll be taking a ride to the dealer this week. Hope they don't try to give me the "it was your fault, no warranty coverage" bs. Thanks for the reply.
Old Jul 8, 2007 | 08:29 PM
DaveJ's Avatar
DaveJ
You used the term "lines" plural. This makes me think of the throttle/idle cables that go into the right side switch housing. If the brake line was loose, I would be surprised if it didn't leak, since it relies on hydraulic pressure to work.
Old Jul 8, 2007 | 08:40 PM
Redsman777's Avatar
Redsman777
Okay, I think you are right. It is specifically the lines that go in beside the "cruise control wheel". One in the front has alot of movement, one in back a little less. Thanks, I'll get it right eventually. I don't know much about my bike yet, but I'm learning. So, should those have movement.
Old Jul 8, 2007 | 08:45 PM
DaveJ's Avatar
DaveJ
Yeah, it's no problem if those cables wiggle a bit.
BTW, it's always a good idea to ask if you're not sure about something; especially if you think it could be an issue with something like brakes!
mglax13
May 29, 2016 04:34 PM
Apr 13, 2010 08:43 AM
devils haircut
May 18, 2008 08:40 PM
braggster
May 20, 2007 10:51 AM
jammer1
Aug 2, 2006 09:28 PM
