Front only solid mount 2005 XL883
Old Apr 29, 2019 | 08:22 AM
HOG63's Avatar
HOG63
Default Front only solid mount 2005 XL883
Hi all.
My front mount on the 2005 XL883 has sagged past an acceptable point. So I’m thinking of replacing it with either an aftermarket harder rubber or just go with a solid (CNC) mount.
I would be leaving the rear and top mounts as is.
Anyone care to comment/advise on such a combination setup?
Thanks
Old Apr 29, 2019 | 09:39 AM
harley506d's Avatar
harley506d
I replaced my soft fronts for the harder aftermarket type and they are fine.
Never heard, or thought about going solid on the fronts though, so cannot advise if a good idea or not.
Old Apr 29, 2019 | 03:09 PM
nettshubby's Avatar
nettshubby
Default Hard front mounts
just a thought, do the harder rubbers give less or more vibration?
what advantage do they give?
Old Apr 29, 2019 | 03:57 PM
harley506d's Avatar
harley506d
I suppose you would expect more vibration, but the originals you are replacing will have sagged so much they are not doing their job very well so the harder ones will seem better anyway.
The advantage is that they will (or should not) sag like the originals.
Old Apr 29, 2019 | 04:16 PM
nettshubby's Avatar
nettshubby
Ok, thanks, will bear it in mind if mine sag, who sells them?
Old Apr 29, 2019 | 04:34 PM
whylee's Avatar
whylee
I would think if you replace one with a solid mount, you risk something breaking or stress cracks. I have seen cars break tranny bellhousings by having solid tranny mounts and leaving the motor rubber mounted.
Old Apr 29, 2019 | 04:36 PM
HOG63's Avatar
HOG63
Thanks. Can you provide a link to the one you got?
Cheers.
Old Apr 30, 2019 | 12:57 AM
harley506d's Avatar
harley506d
A U.K. company, so not much good to you, do an ebay search for your location. https://www.ebay.co.uk/itm/Front-Mot...item5d5a782ed5
Old Apr 30, 2019 | 01:27 AM
nettshubby's Avatar
nettshubby
Default Mount
I would think the replacement medium would be some sort of denser rubber, or synthetic rubber, or maybe plastic, not actually “ solid”!
At most like the poly suspension bushes sold to “tighten” up the movement of the arms etc.
Old Apr 30, 2019 | 03:35 AM
HOG63's Avatar
HOG63
Thanks. Seems the Drag Specialties brand and Biker’s Choice brand (same item?) is the only rubber-type one besides OEM and the solid option by Hardtail Choppers:
http://hardtailchoppers.com/2004-up-...or-mounts.html
Also just found the ‘el cheapo’ Zodiac brand:
https://catalog.zodiac.nl/en/catalog...for-sportster/
