09 883low bogged down.
Old May 22, 2019 | 11:16 AM
Nick Petersen's Avatar
Nick Petersen
3rd Gear
Default 09 883low bogged down.
Hi guys. I bought a 09 883low about a month ago and it's a fun little bike. Monday I noticed when me and a coworker got on the highway I was doing about 35-40mph and the bike stumbled like it hit a rev limiter and the speed went to 0 and bounced back twice. It also felt like it lost power So we got right off and took the downtown path home. Now I haven't done anything to the bike but spark plugs yesterday cause they looked original. and tried riding it gunned it and nothing happened. Maybe it's user error and I was in 1st gear still but I'm pretty sure I was in 2nd. Any advice? Also the bike has a little under 3k on it and it's not the first time I've done highway and cracked into it. Thanks guys.
Old May 22, 2019 | 11:22 AM
Jackie Paper's Avatar
Jackie Paper
Sounds like a bad or loose electrical connection. I would start at battery. I would pull it, put a fresh 24 hour maintenance charge on it . Then carry it in and have it load tested with their equipment set correctly to the low amp rating . Then you will know that is ok and will have a good tight connection.
Old May 22, 2019 | 11:27 AM
handirifle's Avatar
handirifle
If you were in first gear, it WAS the rev limiter. Redline is about 5500 and I hit it on mine a couple time till I figured it out, also by posting here like you did. Its easy and fun to rev em way up there, but not necessary.
Check the battery as mentioned, but my money is on the limiter. What you describe is exactly what mine did. I suspected that was what mine did and upshifted when it did it. Problem solved. Plus I learned to shift a little earlier. Coming from higher revving bikes myself it is a learning curve.
Old May 22, 2019 | 11:37 AM
Nick Petersen
3rd Gear
Ripsaw it's going in next week for a oil change and full service. So will have it load tested as well.
Handirfile yes that's what I'm thinking myself just because the simple fact we were in stop and go and I was in first the whole time. But will check the battery. Thank you guys
Old May 22, 2019 | 12:11 PM
Jackie Paper
Rev limiter should not affect speedometer.
Old May 22, 2019 | 01:32 PM
handirifle's Avatar
handirifle
True I missed that part
Old May 22, 2019 | 02:06 PM
Nick Petersen
3rd Gear
So if it doesn't effect the speedometer I'm assuming it's a electrical problem. But wouldn't the stator be faulty? Since from what I understand the state is like a alternator? Or am I just completely off? Lol
Old May 22, 2019 | 03:23 PM
Jackie Paper
You do simple first. Connections, battery. Obiviously you are not capable of that. So if I where you, I guess I would tell them exactly what it did and hope for best. Stator would be last place to go since it is the alternator and puts out 3 phase 40 volt or so AC. Then to regulator that changes it to 14.6 DC to force it back thru battery to charge a 12.8 volt DC battery
If you tell them stator. They may just ablige you if someone has a boat or car payment shortly
Old May 22, 2019 | 03:38 PM
Nick Petersen
3rd Gear
With the simple fact I have already checked the connections and voltage to the battery I was just curious and asking since you guys have more knowledge. I never said I thought it was the state only asked. So maybe I jumped the gun but I'd rather ask the dumb question then not ask it. But thanks. I'll pull the battery and put it on my trickle charger and take it for a load test.
Old May 22, 2019 | 05:01 PM
Jackie Paper
Cool. Not trying to be a jerk. From post 3, though you were limited to someone working on it. Put your DC meter back on. Watch it carefully (nice to have a freeze frame meter here) When you crank it, it should not drop below 9.6 volts. Once running, throttle up to test rpm 2000 (or fast idle) Voltage should rise to above 13 and stay below 15 even if revved 3-4K.
If it passes that, stator, regulator, and battery are fine.
