New to Sportster. Everything feels right when riding and shifting but it seems very hard to push while in gear but clutch is pulled in. Much easier when in neutral. Is this normal?
Yes. Even when pulled in, the clutch drive and driven disks oil stick to each other like a wet flat plate on a smooth countertop. Also, the actual splines and serrations of the disk are quite snug on the clutch hub, so they do not always separate evenly. Since a Harley transmission gears need to spin so the drive dogs can drop in to engage correct ratio of a gear shift, this is part of the wet clutch design.
However, since I am afar by the internet. Make sure oil level is correct, correct oil and clutch is correctly adjusted by book.
I've had two 1997 883's, a 2002 1200 and a 2006 1200. All four are harder to push around if they are in gear and the clutch is pulled in compared to having the bike in neutral. Also I can feel the bikes pull just slightly when I first start them up with the bike in gear and the clutch pulled in. All of the clutches have been adjusted per the book. So I think it's normal.
As a side note, if you ever leave your heated grips turned on and kill your battery in a parking garage, roll down the ramp in neutral to pick up speed, then shift into 2nd and release the clutch to bump start it. If you try to roll down the ramp in 2nd gear you will not get up enough speed, and pushing a sportster up the ramp, even in neutral, to try again sucks.
I'm guessing that you're speaking from experience.
