TIMER COVER REPLACEMENT
Old Jul 12, 2007 | 10:06 PM
FATBOYUSA's Avatar
FATBOYUSA
Default TIMER COVER REPLACEMENT
[sm=biker2.gif][sm=biker2.gif]HOW DO I REPLACE THE STOCK TIMER COVER WITH THE FLAMES HD COVER, WHEN IT IS RIVOTED ON? I AM AFRAID IF I DRILL THE OLD RIVOTS THAT PART OF THEM MAY FALL IN THE BLOCK.
[IMG]local://upfiles/37276/547C500678CB44F9A0DF89654208B824.jpg[/IMG]
Old Jul 12, 2007 | 10:21 PM
DaveJ's Avatar
DaveJ
Default RE: TIMER COVER REPLACEMENT
They are not rivets. They are torx screws.
[align=left] [/align]
Old Jul 12, 2007 | 10:28 PM
Dallastx's Avatar
Dallastx
Diamond. They are auctioning popsicles on Ebay. Go quick!!! 15 minules left!
Old Jul 12, 2007 | 10:34 PM
HighDesertKid's Avatar
HighDesertKid
You're going to need the HD2000 with the diamond heads.... use your flux capacitor for power
Old Jul 12, 2007 | 11:27 PM
LittleBrother's Avatar
LittleBrother
ORIGINAL: HighDesertKid
you need 1.21 jigawatts!!!!!!
-LB
Old Jul 12, 2007 | 11:51 PM
FATBOYUSA's Avatar
FATBOYUSA
[sm=vader.gif]MINE ARE ON WITH RIVOTS. I AM NOT TALKING ABOUT THE INSPECTION COVER, BUT THE TIMER COVER THAT SAYS 5 SPEED ON IT.
THE NEW ONE EVEN COMES WITH RIVOTS.
Old Jul 12, 2007 | 11:54 PM
Kolni's Avatar
Kolni
ORIGINAL: Dallastx
LIAR!!!
Old Jul 13, 2007 | 12:31 AM
DaveJ's Avatar
DaveJ
ORIGINAL: DIAMONDPLATE
When I saw your initial post, I was thinking you had a newer model for some reason. I have never wrenched on a 2000 Sporty, so I guess I can't answer your question. Did it come with instructions? Do you have a service manual?
Old Jul 13, 2007 | 04:49 AM
smokeygold's Avatar
smokeygold
POPCYCLES.... I WANT ONE!!!
Old Jul 13, 2007 | 05:24 AM
MidWest XL's Avatar
MidWest XL
I did this a year or so ago. Go ahead and drill them out. There is actually another cover behind the outer one. HD provides special rivets to replace the cover. Standard rivets,when installed, could break off the little "ball" inside. HDs won't.
But, like I said, there is another "real" cover behind the outer cosmetic one.
Oh, and, by the way, I do wear reading glasses, but your text size is readable from the other side of the room!
