checking oil
Old Aug 13, 2019 | 07:36 PM
gerald martin's Avatar
gerald martin
Default checking oil
Another question. I have a 2005 883 low. How do I check the oil, on kick stand or standing up straight? The service manual and the owners manual both say on the kick stand but when I get the bike up to operating temp and fill the oil almost to the full mark while on the kick stand when I stand the bike up the level is a way above the full mark. If I then put it down on the kick stand again and suck out enough oil to get it to a little less than half the dip stick then when I stand it up it is just a little over the full mark. Is the manual wrong or what?
Old Aug 13, 2019 | 10:27 PM
nathan-hd48's Avatar
nathan-hd48
What's the engine oil capacity? Is this following an oil change? Are you leaking oil that you need a regular top off?
I'd go with the manual and check with the jiffy stand down. Some models also have cold and hot level indicators.
Old Aug 14, 2019 | 02:55 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
In which document are you instructed to stand the bike upright in order to check the oil level?
If it is coming from a mate then ignore him.
Just go by the owner's manual.
Old Aug 14, 2019 | 03:20 AM
Midpegs's Avatar
Midpegs
Well it would, wouldn't it ? Why worry about it ? It's designed to make it easier for you . Why would you want to have to use a lift to top up the oil ? It's not even that critical , as long as there is sufficient to feed the engine you're ok .
Old Aug 14, 2019 | 06:36 AM
VAFish's Avatar
VAFish
Then follow the service manual and owners manual. Checking while the bike is on the kick stand is the proper procedure. Why would you think that BOTH the service manual and the owners manual were wrong?
Old Aug 14, 2019 | 07:43 AM
cacomly's Avatar
cacomly
It's simple, the dipstick is calibrated so it is accurate when the bike is on the side stand. When the bike is in any other position it is not.
Old Aug 14, 2019 | 07:51 AM
Andy from Sandy
I think it would be good if the OP could reveal why he is checking the oil level the way he is.
People do come up with very good working practices that differ from the manufacturer over time but this time is not one of them.
Old Aug 14, 2019 | 09:45 AM
gerald martin
The reason I am asking this question is that when I stand the bike up it is way over the fill mark and it seems that maybe there is too much oil in the tank and could cause blow by as the manual also says not to over fill the oil tank. I am not that familiar with sportsters so that is the reason for my question but if everyone else is checking on the kick stand that's what I will do also
Thank you all for your replies
Old Aug 14, 2019 | 11:43 AM
nettshubby's Avatar
nettshubby
The dipstick is calibrated to get the correct level on the side stand, period!
SoftailSlim_Rider
May 16, 2018 12:29 PM
Spucky
Feb 22, 2015 12:11 PM
MikeLaPlaya
Jan 19, 2015 02:26 PM
bigredwing
Nov 1, 2014 06:40 PM
steelhorse1
Sep 16, 2008 01:58 PM
