I see bikes with the larger extra lights at the front on all the time like running lights. Are they supposed to be switched so they are normally off?
If you say you flash them to let the person in front know you are passing them then or indicate you want them to pull over then you best not come to Europe as it is frowned upon. In Germany it gets you a fine.
If they stay on all the time like running lights then I guess you can use the power that you already have to your front turn signals. There is a 6 way block under the tank.
