Thank you.
As fast as she has gone so far it stays upright. It does have an anti roll bar fitted.
The back end is a bolt on kit so there was no modification to the frame. It uses the top shock mounts and swing arm mounts. The tubing is real heavy and the largest from any company in the UK. The downside is the whole trike is now 100Kg heavier than it was when a bike.
The running gear is from an E39 5 series BMW.
Still very capable running at 80mph. Cindy hasn't admitted if she has gone any faster.
I know the axle in front is supposed to be safer, and handle better, but they just look odd to me. I looked st their kits, and the Harley, just looks really strange.
Andy,
Yes, not quite as easily, but only maybe 10 seconds longer to detach. The only change to removing the bags is to disconnect the wiring. Even that is simple. This is not the link but is the style of connectors I used.
