Electrical issue 04xl1200r
Old May 5, 2020 | 05:45 AM
Jade Beardcore's Avatar
Jade Beardcore
4th Gear
Default Electrical issue 04xl1200r
Hi everyone, long time listener, first time caller. My sporty has been down for a couple months and I'm at my wit's end with it. Recently replaced my stator, starter, and flywheel, and after putting everything back together, I've encountered a weird issue. When I attempt to reconnect the battery, the positive lead arcs like hell and instantly starts melting the terminal. Asking around people have told me I have a short, or my battery is bad. I've replaced with a new battery to no avail, and have yet to find a the short. It should be noted that this only happens when connecting the lead from the starter, the other line with the maxi fuse works fine. Due to the current lockdown I am also unable to take it to a shop, they're all closed around here and have a 6+ month backlog of repairs. Any help appreciated. Thanks!
Old May 5, 2020 | 06:25 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Give us a baseline here...
Why did you replace the stator, starter, flywheel (I`m thinking you are actually meaning the alternator rotor)?
Old May 5, 2020 | 06:28 AM
Jade Beardcore
4th Gear
Old starter was done for, and chewed up the (at a loss for the name right now, the wheel it spins to turn the motor over) so I replaced both. Did the stator while I was in the primary as it was pretty black.
Old May 5, 2020 | 06:33 AM
Baird's Avatar
Baird
The starter motor seems always connected via the solenoid and is perhaps seized somehow, or there is a ground in the solenoid.
Old May 5, 2020 | 06:42 AM
Jade Beardcore
4th Gear
How could a seized motor create this issue? I had thought the solenoid could be grounding, but no idea what to do about that short of a new starter that I can't really afford.
Old May 5, 2020 | 06:48 AM
Architect's Avatar
Architect
Start with the basics. You have a short, the battery cable arcing all over the place tells you that, so you have a problem.
The mostly likely culprit is you mixed up some wires during the installation. No worries, it happens.
Go back wire by wire and check all of your connections VS your Factory Service Manual. Check that they are all clean with good connections. Check all the wires for exposed copper, fraying or general wire disrepair.
If all is at it should be and all the connections are clean and in order then we need to talk some more. Good luck.
Old May 5, 2020 | 07:59 AM
Baird's Avatar
Baird
I mean the starter motor. Electric motors that can't turn are very low ohms almost a short and draw very high amps like you saw when you touched the lead to the terminal.
. Good advice from Architect, I kinda assumed you double and triple checked the wiring.
Old May 5, 2020 | 01:37 PM
08xl1200r's Avatar
08xl1200r
For test purposes ONLY you could wire a small 12V bulb temporarily between the battery and the cable...so long as the short is present it will glow at full brightness but will limit current i.e. a 12W bulb would only pass about 1 amp max. When the short is gone the bulb will go out, or at least become very dim... Do not try to turn the bike on or start it with the bulb connected, it is only used to find a dead short like you evidently have.
Old May 5, 2020 | 02:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
If there is a short that is drawing enough amperage that it makes the battery terminal hot, it must be between the battery and the starter.
Only the battery cable could carry enough amperage to do that, if it were one of the smaller wires, the small wire would be toast, or the main breaker would trip.
There are two big terminals on the starter solenoid, measure the resistance between them. It should be infinity.
Just a safety note here, always connect the positive terminal before connecting the negative terminal.
Old May 5, 2020 | 02:45 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Not possible on a 2004 bike. The negative has to be connected first then the battery is pushed into / onto the shelf.
