Melted headlight plug
Old Jun 16, 2020 | 07:05 AM
MichelleBacon's Avatar
MichelleBacon
6th Gear
Default Melted headlight plug
2014 Sportster 1200T: high beam failed a few days ago. Finally got around to purchasing a replacement bulb, only to pull everything apart to find that the plug melted... Anyone else ever have this problem?
Old Jun 16, 2020 | 07:17 AM
John Harper's Avatar
John Harper
Gnarly. What wattage bulb are you using?
John
Old Jun 16, 2020 | 07:21 AM
hammer6315's Avatar
hammer6315
not me. perhaps a defective connection that resulted in arcing/melting?
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Once you have tracked down the reason, H4 plugs are easy to come by and crimp on.
What are those stalk things sticking out? I have fitted a few bulb connectors and never seen that.
Old Jun 16, 2020 | 07:23 AM
Iceman24's Avatar
Iceman24
Nice 1st post - care to elaborate. Any electrical mods we need to be aware of, is that the OEM headlight?
Old Jun 16, 2020 | 08:17 AM
MichelleBacon
6th Gear
Those things sticking out are the guts of the bulb itself...
Old Jun 16, 2020 | 08:22 AM
MichelleBacon
6th Gear
No electrical mods. At one point I did have a Daymaker installed, and once the glass broke, I re-installed the factory light. The bulb that was sold to me back in September is a Halogen H4 100/55w. Generic type.
Old Jun 16, 2020 | 08:31 AM
MichelleBacon
6th Gear
**Learning curve, sorry lol...
Those things sticking out are the guts of the bulb itself... A friend and neighbor was kind enough to help me crimp on a new ceramic H4 plug, no more melting!
Old Jun 16, 2020 | 08:46 AM
pococj's Avatar
pococj
That 100/55 halogen is the problem. IIRC, the standard bulb is 60/55 watts. Running the 100w means that the current is nearly doubled, and the higher temperatures melts the stock connector. I used to run a 100/60 H4 and replaced the plug with a insulated metal version designed to carry the higher amps of the 100w bright. Even then the standard wiring started showing signs of overheating so I went up a couple of gauges on the size.
Old Jun 16, 2020 | 08:52 AM
MichelleBacon
6th Gear
Had a hunch. Once I called HD to get the bulb type and size that was sold to me, I went to the website of the store I purchased the new bulb from. The new one is 55/60... My wiring also showed the same heat damage, had to be trimmed back fairly significantly.
