Clutch pull
Old Aug 16, 2020 | 11:21 AM
Motocross434's Avatar
Motocross434
6th Gear
Default Clutch pull
I bought the wife a 05 sporty clutch pull is to hard for her .I lubed and routed the cable correctly.but still hard to pull.can anyone tell me what clutch ease kit works the best.? Thanks. jim
Old Aug 16, 2020 | 11:30 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Old Aug 16, 2020 | 08:34 PM
Madnss's Avatar
Madnss
https://aim-tamachi.com/collections/vp-sportster
i have 2 Xl’s and run this. Both 120 plus hp and I leave the drag strip line with two fingers on the clutch. Way easier pull than any 883/1200 stock set up. I’ve never used any easy pull kits. But this Aim hat will reduce clutch pull significantly
Old Aug 16, 2020 | 08:51 PM
215sporty's Avatar
215sporty
This may be wrong, but i had a heavy clutch pull, so i adjusted my clutch in the case and then the cable itself, then lubed up the lever. Way lighter pull now.
Old Aug 16, 2020 | 10:27 PM
lewk's Avatar
lewk
Which one for the 1275cc kit?
Old Aug 17, 2020 | 01:52 AM
Midpegs's Avatar
Midpegs
Mine came with a Muller Power Clutch and even with a 15% stronger spring it's still much lighter than the hydraulic clutch I had on my GSXR 1100 . But as previously mentioned , you have to work the clutch a lot more on a Sportster especially in traffic . Also , the fact that I've been pulling clutches for forty years might give me an advantage .
Lunchboxx
Aug 17, 2019 12:46 PM
Steve Barber
Aug 14, 2019 08:42 AM
SixDD
Jul 19, 2019 07:56 AM
rick775472
Jul 5, 2015 09:08 PM
06kustom
Mar 13, 2009 11:20 AM
