Bars Question........wait. it is about install
Old Jul 26, 2007 | 06:29 PM
kawsakimx6's Avatar
kawsakimx6
Default Bars Question........wait. it is about install
I am getting mini Apes this weekend. (i think) my question to you is What all will i need to do this my self? will i need to make the brake likes, and all other cables longer? and what all tools will i need? Is this something i can do myself easily? or should i bring it to the dealer?
Old Jul 26, 2007 | 06:34 PM
6o66er's Avatar
6o66er
Default RE: Bars Question........wait. it is about install
12" or under you can keep your factory throttle/idle cables, clutch will need to be a +4 over, I believe. Brake lineneeds to be at least44" with a 45* connector at the master and a 90* at the caliper for a perfect fit.
EDIT: Just to prevent minor annoyances...hard mounting your risers is a good idea.
Old Jul 27, 2007 | 06:45 AM
dbleagle's Avatar
dbleagle
I've done mine... got all new cables and brake line...
You have to also extend you wiring...
Special tools... soldering iron/wire... some electrical wire... shrink tubing... harness loom (to make it look more factory)...
Gotta have the right size allen wrench for the bar clamp... torque wrench...
I originally did mine without a torque wrench... but ya' gotta know when tight is tight and not over tighten...
Charlie D.
Old Jul 27, 2007 | 02:04 PM
6o66er's Avatar
6o66er
Also, for the wiring, you can use Brae connectors in place of soldering, make sure you shrink wrap EVERYTHING with bare metal on it.
When you clip the harness, use equal lengths of wire to splice and cut eachwire on the harness in a different spot. This will prevent a major bulge on the harness once you're done and if you run internally it won't make it impossible to pull them through. Also looks clean once you cover them.
chad.kirk1
Jun 21, 2017 05:39 PM
96SportyCustom
Jul 3, 2015 12:10 PM
XKROME
Nov 9, 2008 06:43 PM
third_left_eye
Feb 18, 2008 08:14 PM
humpbackbob
Dec 23, 2007 05:30 PM
