2000 Sportster oil leak
Old Dec 1, 2020 | 04:51 PM
Alethia Brhel's Avatar
Alethia Brhel
Stage I
Default 2000 Sportster oil leak
I went to check my 2000 HD Sportster 1200 oil and it was almost completely empty. I noticed it was leaking from here. The bike is also running rough and wont stay running. Where is it leaking from and what do I need to fix it? thanks!
Old Dec 1, 2020 | 06:43 PM
Midpegs's Avatar
Midpegs
I'm sorry to be the bearer of bad news but I believe that's your head gasket . To fix it you need a new head gasket , and someone with the equipment to check for distortion of the head and barrel .
Old Dec 1, 2020 | 06:49 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Did you run the engine before checking the oil level? If not some of your oil may have gotten past the check valve in into the sump. Start the engine, let it run for a minute, shut off and then check the level.
As for the leak - as stated looks like a head gasket. Clean it off with some brake cleaner, then run the engine and check the area for leaks. May be as simple as replacing the head gasket or there may be an issue with the head. The only way to know is to take it apart and get it checked. Good Luck!
Looks like there is some oil on the exhaust flange also, check the other side to see if it migrated from somewhere else.
Old Dec 1, 2020 | 11:49 PM
cncmike's Avatar
cncmike
There are O-rings around the studs in that area. The heads have to come off
pierre apostolos tzannis
Jun 21, 2020 12:20 AM
Tbelanger
Apr 28, 2015 02:22 PM
Andy Ross
Oil Archive (no new posts)
Oct 24, 2014 06:45 PM
mgabe2706
Aug 22, 2012 09:53 PM
Jwigg
Jul 25, 2011 10:52 AM
