2012 sportster xl 1200
Old Mar 17, 2021 | 08:04 PM
Jason witterman's Avatar
Jason witterman
Stage I
Default 2012 sportster xl 1200
So i just bought this bike a week ago and its got v and h short shots and a v and h fuel pak and a roland sands air filter bike was acting up not wanting to start called the guy i bought it from and he said take the fuel pak off. I did the bike ran great for a couple of days. Then it started back firing and acting up again so i parked it. the next day was going to put the fuel pak back on but i noticed the oil light is on as well as my neutral light with out the key in the bike.
and now i dont have any thing no power bike will not turn over am lost any help would be great
Old Mar 18, 2021 | 04:37 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
So with the ignition turned off you have two indicator lights on. That clearly is an electrical issue that has resulted in the battery draining.
This could be a two minute job or could take a very long time to find IDK.
Wiring diagram - 99949-12_en - 2012 Wiring Diagrams | Harley-Davidson SIP (harley-davidson.com)
Looking at the wiring diagram it could be the ignition switch is faulty. Look for the path of power to those lamps.
Old Mar 18, 2021 | 06:01 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Looks like you have a short somewhere. As above wiggle the ignition switch and see if anything changes. Get a HD Service manual & Electrical diagnosis manual or take it to someone who knows what they are doing. Good Luck.
Old Mar 19, 2021 | 12:08 AM
slickman's Avatar
slickman
Sounds like you have a ignition switch problem and may be causing all your issues.
Old Mar 19, 2021 | 12:09 AM
slickman's Avatar
slickman
Oh, Also if you're interested in selling the fuelpak, let me know
Old Mar 19, 2021 | 12:54 PM
Dale f's Avatar
Dale f
Stage I
Default Spark plugs
I'm new to this im trying to ask a question maybe you can help can I run hot fire plug wires on a stock sportster without doing anything else I put screaming eagle plugs in made a diffence can I know up grade my wires
Old Mar 19, 2021 | 01:35 PM
Andy from Sandy
Dale you are probably better off starting your own thread to ask your question.
And welcome to the forum!
FLXSporty
Apr 9, 2020 03:16 AM
Texas1982
Nov 18, 2016 06:06 PM
scg661
Oct 20, 2014 07:29 AM
cameron.woolery
Sep 21, 2012 01:21 PM
