Is there such a thing available, and what does it take to install? Thank you!
You did not indicate what year you are working with. If its 10years or more, most
likely one of the new teflon lined cables will reduce the pull effort...
I installed AIM Variable Pressure Clutch (VPC) which has weights that use centrifugal force to increase clutch pressure as engine speed increases. It definitely reduced level pull and works pretty well. Not too difficult to install, either. I did not have to remove the primary cover to do it.
Looking again at the picture above of the HD part it looks like the mould has gone to hell but no-one can be bothered to make a new one. Look at the quality of the Muller product it sure puts the HD part to shame.
Picture looks like "original vs cheapocopy"... but vice versa
My bike came with a Muller already installed . Works fine even with a 15% stronger spring but I've nothing to compare it to . One thing , with a Muller you only need to back off the adjuster 1/8 of a turn instead of 1/4 .
