Paint can Rattle
Old May 21, 2021 | 07:37 AM
slw210's Avatar
slw210
Accelerating from 1500 RPMs in which gear? Yes, sounds like you are lugging the motor most likely, so yes, it's pinging. My Sportster stays 2500 RPM and above except for idle, closer to 3000 RPMs most of the time.
Read this, on timing....Solving Harley-Davidson Sportster Detonation Problems (nightrider.com) I have the Buzz Buzzelli's book if you want more info, I'll see if I can locate it. You should look through the nightrider site as well.
Old May 21, 2021 | 07:50 AM
John Harper's Avatar
John Harper
Did you adjust your timing with the 1200 kit? The 883 ignition curves may not be compatible. When I did my 1250 build, I also upgraded the ignition module and re-timed it per the 1250 vendors specific instructions. SLW210's advice is good, keep that sucker revved up, these engines do not like to be lugged like the big twins.
John
Cajun Fat Bob
May 14, 2014 08:27 AM
shortride
Dec 17, 2009 08:41 AM
jb247
Jul 29, 2009 09:20 PM
Soldierz
Feb 14, 2009 12:15 PM
lowhog
Oct 28, 2007 10:08 AM
