Jammed Starter. .??
Old Jun 18, 2021 | 12:13 AM
Gumpy's Avatar
Gumpy
6th Gear
Default Jammed Starter. .??
My sons 01 Sportster seems to have a stuck/jammed starter. My guess is he hit the start switch while in gear and brake on.
Key on, no lights, no starter reaction.
pull brake….headlights on, neutral and oil light on, hit start and the starter clicks and buzzes.
Tried pushing while in gear and rear tire is locked up
Thought I should post this and see if anyone has any magic up their sleeve before I start taking things apart
Thank you in advance for your help.
Old Jun 18, 2021 | 12:31 AM
Midpegs's Avatar
Midpegs
I wouldn't worry about the starter motor just yet . I'd be more concerned about the fact that you need to pull the brake to turn the electrics on . Have you jet washed it recently ? Water in a multi pin connector can do some very strange things . Until I tracked it down , I was able to switch my bike on and off with the horn button at one point .
Old Jun 18, 2021 | 08:56 AM
im's Avatar
im
Remove battery.
Take battery to be tested.
Old Jun 18, 2021 | 01:50 PM
Gumpy's Avatar
Gumpy
6th Gear
Definitely not a wet or water issue and a mew battery with > 12 volts…
Old Jun 21, 2021 | 11:45 PM
Gumpy's Avatar
Gumpy
6th Gear
Well if it was jammed it isn’t anymore…just another dead starter…
Rooster59
Aug 17, 2015 06:00 AM
eng23ine
Jun 18, 2013 08:30 PM
liljon140
Apr 6, 2012 06:24 PM
bob
Mar 27, 2005 02:09 AM
