Im Kassa, brand new to the forum and new to HD too. I had to jump start the 48 I have as I didnt use it for a 2 weeks or so. After I started I got check engine light and didnt go away. I reset the light and I got the error code on the display as Pn 001443-01. Trying to google but no luck. Any ideas? Thanks alot in advance fellas!
Thanks you very much for Andy and CoolBreeze. Lessons learnt for me.
Do you recon the check engine/error code will pop up again if there is an issue? OR should I take it for a check up? Thanks again
Ride it and if the check engine light comes on, get the codes and list them or look at the fuel moto site for the codes. If the check engine does not come on, you are good. The check engine light will come on when you first start the motorcycle but should go away in a few seconds.
Thanks a bunch CoolBreeze. That helped to calm the nerves
