Data link not working
Old Aug 23, 2021 | 02:24 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Check for codes
Harley Trouble Codes (fuelmotousa.com)
Old Jul 21, 2022 | 04:24 PM
firenfly's Avatar
firenfly
Stage I
Did you ever figure this out? I’ve got the same issue on a buddies bike and I’m just about stumped at this point. He has an fp3, but getting no power to the data link. I’ve also tried plugging in my tuner for my bike and it doesn’t power up either so I know it’s not the fp3
Old Jul 22, 2022 | 04:31 AM
Andy from Sandy
Can you confirm on the plug of the FP3 if there is a wire to pin 5 or pin 6?
Pin 6 is always on and is fed from the P&A fuse. Pin 5 is Accessory Power from pin M2 of BCM.
Confirm pins in DLC have not been pushed out? Even though there might be power if any of the data pins are not connecting the tuner will not work.
Check on the DLC connector positive of voltmeter to pin 6 and negative lead of voltmeter to pin 2 with ignition on or off should be battery voltage. Then check with positive lead of voltmeter to pin 5 with ignition on and off. It should be battery voltage when the ignition is turned on.
By connecting the negative lead of the voltmeter to pin 2 on the DLC connector you are confirming both wires are good.
schnorrbusch
Dec 25, 2013 10:25 AM
chgofirefighter
Nov 21, 2013 08:16 AM
harleyglen
Feb 10, 2013 01:17 PM
Astride
Exhaust System Topics
Dec 3, 2012 01:51 PM
valacech
Aug 31, 2010 09:44 PM
