Sticky throttle
Old Sep 17, 2021 | 06:38 PM
_cp3's Avatar
_cp3
Stage IV
Default Sticky throttle
02 sporty, got new vans grips. Had to adjust the cable tensioner to remove the sleeve and slide my new grips on. Also cleaned the carb. Now I get no snap back on the throttle. Could it be the cable tensioner? I noticed it snaps back perfect when the engine is not running. When I start it up, throttle gets stuck. Cable tensioner? Throttle body? Maybe cable binding when I put the carb back? Any tips, thanks.
Old Sep 18, 2021 | 09:05 AM
Acrodave22's Avatar
Acrodave22
I had this problem, and found a cable tension (pretty slack) which would work, but it, obviously was not right. It turned out to be that some of the glue that held the grip to the plastic tube had pushed back near the end and hardened. That then was rubbing on the handlebar end, causing friction. Removed the excess glue, and it worked perfectly with any cable adjustment. I suspect the cable tightness was pulling the grip inward, causing the rub, hence the lighter tension worked, somewhat.
In thinking about it, if the switch housing were just a bit too far onto the bar, it could cause this problem, without the excess glue.
Old Sep 18, 2021 | 11:04 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
When you fixed the housing on the bars did you ensure there was little end float play in the twist grip?
Old Sep 18, 2021 | 01:02 PM
83XLX's Avatar
83XLX
Slide the throttle housing out a mm or two.
a207769s
Carburetor Related
Sep 5, 2020 10:32 AM
Baja272
EVO
Feb 27, 2016 08:32 PM
KDagostino
Apr 8, 2013 08:44 PM
sportyslr
Exhaust System Topics
Jul 18, 2005 01:31 AM
HDF Tech
Jul 18, 2005 12:22 AM
