Oil capacity with an oil cooler
Old Dec 6, 2021 | 10:21 PM
Stevoknievo68's Avatar
Stevoknievo68
Default Oil capacity with an oil cooler
I have an oil cooler that I have yet to install on my 2021 Forty Eight as I'm waiting for the dealer to recieve and install a new tank for me since Mr. Magoo decided he wanted the lane I was in. But I have a question about running the said oil cooler. Will I need to increase my oil volume to make up for what will be in the channels of the cooler?
Old Dec 7, 2021 | 01:43 AM
Midpegs's Avatar
Midpegs
I would have thought so . If you check the oil hot using the dipstick you can't really go far wrong .
Old Dec 7, 2021 | 03:36 AM
eighteight's Avatar
eighteight
It`s minimal, as an example a Jagg 6 row adds 6oz, a 10 row , 8oz
Don`t over think it , see comment above
Old Dec 7, 2021 | 04:51 AM
firehawk6's Avatar
firehawk6
I have the Jaggs 6 row on my '17 and I have always drained the oil, rocked the bike side to side a few times to drain out all I can, and replaced the filter. I pour in 3 quarts of oil and have never had an issue in almost 27,000 miles.
I recently changed out the black rubber oil lines running to the cooler with braided stainless steel ones. Very little oil drained out of the cooler, it was such a small amount I didn't even bother to add any oil back. Still reads full on the dipstick.
Old Dec 7, 2021 | 05:36 AM
FreedomRider's Avatar
FreedomRider
It's not enough to worry about ... do the regular oil service and ride it ... Harley motors are dry sump, meaning they run on around a cup or two of oil in the motor,, the rest is in the tank ... the cooler doesn't use enough to change anything
Old Dec 7, 2021 | 05:46 AM
Midpegs's Avatar
Midpegs
All of the above begs the question , are oil coolers actually very effective and if so , is this actually quantifiable ?
Old Dec 7, 2021 | 05:56 AM
firehawk6's Avatar
firehawk6
In hot 90*F or higher temps at Interstate speeds (70 mph) I was seeing oil temps right at 250*F, too hot IMO. After adding the oil cooler I'm lucky to see 220*F under the same conditions. Worth every penny IMO.
Old Dec 7, 2021 | 06:27 AM
Stevoknievo68
Not sure if they were always needed but with the lean AFR Harley has been subjected to it does make a difference in engine heat and you can tell by feel and sound when the engine is getting too warm. I tend to ride long miles (which makes one wonder why I ride a Forty Eight) and I have experienced this first hand as anyone who is running the lean standards no doubt has.
Old Dec 7, 2021 | 06:30 AM
Stevoknievo68
Thanks as I do tend to over think things and the previous comment had me rolling my eyes at myself...
Old Dec 7, 2021 | 06:45 AM
eighteight's Avatar
eighteight
I`ve used them for years and have no data to prove the results
But, I`m pretty sure " it can`t hurt " !
